Transmission fluid
Sonoma, CA
Website
www.myspace.com
I was changing my oil today and a friend decided to stop by and help. Unfortunately, he unscrewed what I believe is the transmission fluid drain instead of the oil.
So both of the autopart stores in town were closed by the time I got off work.
Sooooo.
Grocery store. The owners manual said to use "Dexron II" transmission fluid, but all that was available was "Dexron III."
Is it the same thing, is it okay for me to use? I just need a quick "yes it's okay" or "don't use it."
Thank you.
Dextron III superseeds Dextron II in all respects, so it is all you will find. Just make sure the ATF you buy is a well known name brand, not some plain label supermarket stuff.
I got Penzoil. I could have bought Safeway brand, but at a buck fiddy a bottle, I figured I'd be better off with whatever costed more.
30k is ok. However some owners drain the trainy every oil change (4-6 qts) to keep a flow of fresh fluid. Many threads covering this one. Be a good owner and do a search. Last note, it really all depends on how you drive and the abuse you put her through.
