Transmission flare....?
Utah
Symptom: Transmission will 'flare' while driving a steady speed. (By flare- I mean rev up and down seemingly willy-nilly). Sometimes will seem to loose power, can not get it to replicate by my input. Seems to do this at it's own 'will'.
Generally happens between 25-30 MPH and flares between 1500 and 2k rpm's
Sometimes it will flare up and back down, then right back up and back down again- multiple times in the same 'episode'. All this occours while trying to maintain a steady speed.
It's like it's 'searching' for the right gear. This just started last week.
Is this a Kickdown Cable Adjustment issue?
How's your fluid level and colour? Does it smell burnt?
I haven't checked it. It is not leaking, however, as I would notice that where I park. So, the level is more than likely good- I don't know about color or smell. I could check tonight.
I think this is a relatively common issue with the a442f's. It is not serious at all. My old 1994 fzj80 would flare on light throttle on the upshift from 1-2 I think (maybe it was 2-3) whenever it felt like it. Never got any wore or affected the operation of the transmission. Worked flawlessly (other than that) for 250k miles and I'm sure someone is still driving it somewhere.
But if yours is flaring after you drive the truck for a while and on only hard throttle, you may have a serious problem.
It did it again yesterday. My original RPM estimate was wrong. It's happening between 1500 and 2000 rpm's. Generally under light throttle or no load. Will occasionally happen under decelleration.
Yes, I forgot to check the fluid again.
possible remedy
Doc, this is an expert on the 2nd gear flare ;-)) I had this problem almost 5 years ago however, mine occurred under HEAVY acceleration and hit 2nd gear HARD. Anyway, I don't understand why it would occur under light throttle.
My issue was remedied with a "valve body job". A valve body redo basically pushes the tranny fluid sooner within the valve body....making it shift quicker and crisper. It's about a $500.00 job. But my confusion is why it would do it under light throttle . I don't think it's your tranny going out..but a valve body redo.
airlaird
Thanks Herr. Laird- I shall look into that.
