Transmission Drain Plug/Bolt
Northwest Florida
Hey guys, recently did a transmission pan flush, but have now encountered a leak from the drain plug/bolt. I checked and there is no washer where as the fill bolt does have one. Is the drain bolt/plug on the transmission supposed to have a washer?
Which fill bolt on the transmission are you referring to?
The transmission fluid fill bolt/plug. The fill bolt/plug has a washer but the drain one doesn't and was wondering if that's why that bolt is leaking.
There is no transmission fill bolt on the AUTO, at least on the 343. I assume we're talking about an AUTO here? You fill from the AUTO dipstick.
The AUTO drain bolt SHOULD have a washer. Ditto for the engine oil drain bolt.
Sometimes the washer 'sticks' to the bottom of the pan (on either), make sure you remove it and replace with a new one (cheap, I usually pick up 4 or 5 of them when I've used up the last one).
Also, nice if you ADD YOUR MODEL YEAR ETC to your SIGNATURE...
cheers,
george.
I think there is a bigger problem then. I pumped a good amount of fluid in what I thought was a fill plug....
Sorry, ill add the specs to my signature right away. I have 1992 Land Cruiser FJ80 with 3FE motor - Auto trans.
I think I have the A440F transmission. Please tell me it has a fill plug. Lol If not, I'm curious as to where that fluid went... Haha
A picture of what you think the 'fill plug' is would be a good thing for us to look at (and maybe laugh at)... Maybe you went and filled the transfer case... Maybe you drained the transfer case too. PICTURE....
The few auto vehicles I've had are always filled via the auto dipstick...
Thanks for adding info to your sig - helps us know what you actually have.
cheers,
george.
I put my finger down in hole where the bolt was removed and it wasn't a fastener of any sort. It was almost identical to the drain plug. If it isn't a fill plug, its a hole to a container of some sort because I pumped almost 6qts of ATF in there and it never overflowed or leaked until I drove it. Then it leaked out of the drain plug. Very small amounts around the drain plug bolt, like it escaping from not having a washer or seal. lol
Well, if that feeds into the transmission sump your ok...
BUT, you are meant to FILL through the dipstick.
There SHOULD be a washer on the drain plug. Make sure the original isn't 'stuck' to the bottom of the pan.
cheers,
george.
Awesome! Whew.....close one! I was definitely in panic mode. haha Next time I will fill with dipstick....its just the neck of the dipstick is so small.
Ok, cool! Ill pick up a new washer. Can I get them at Autozone, etc... or is it special and come from a Toyota dealer?
Thanks guys!!
I get mine from toyota, they're cheap (get the ones for the oil drain while you're there). The dealer near me has a 25% TLCA discount, so that helps even more. If I'm ordering a bunch of stuff from Cdan etc then I just add to an existing order. Beats looking for something generic that fits.
I keep an old 1qt diff oil/atf fluid bottle - the type with the pointy tip. Cut the bottom off and you have a funnel to fit into the auto dipstick filler.
cheers,
george.
Crush washer / trans. pan drain plug >12157-10010
