Transmission cooler
Akron Ohio
Hi Guys,
long time lurker, first time poster..
I just bought a 96 LC from its only owner, and they replaced the radiator recently, however it looks like there is not a transmission cooler in the lower front where one should be. There is a cooler on the right side of the radiator, but should there be two? Im guessing there is two trans coolers.
Can anyone find me a diagram of how its supposed to be routed? Or just a picture of the stock coolers?
Thank you,
Chris
in front of the radiator is an ac condenser and a tube and fin trans cooler. there is also a trans cooler inside the bottom of the radiator...
Well I should say a trans cooler in the radiator and the one in front that I must be missng then the oil cooler as shown above, that I do have.
the picture above is of the trans cooler, the engine oil cooler is on the block....
Only thing behind the bumper is the power steering fluid cooler. which is basically a hard line with a couple of 180 degree bends in it. Looks similar to a large paper clip, which is what some people call it.
ok it's probably me, but what makes you think there's something missing....
... looking for something that's not there could be tricky. :D
When I first got under the front of the truck checking it out, I noticed on the driver side there was a rubber hose that was looped from a hard line back to another hard line, like they removed something.
Then it looked like there was an empty bolt hole where something used to be closer to the passenger side. I may just have to take a picture when I get home to explain it.
it just looked like something was missing.
After doing some googling and getting back under the truck, its the power steering "cooler" that is missing. Im going to buy a Derale one to replace it.
Thanks for your help!
