Transmission cooler
PabloVTA
beside La Caja China
Ventura Ca. USA
Has anyone installed one of these?
Looking for tips on where to put this, since it doesn't need direct flow to work.
Any advantages or disadvantages?
Personally, I think the OEM cooler is adequate for the job. When I rebuilt the entire engine bay, I took the OEM cooler and had it hot tanked and rodded. Waste of money. It was fine as is. I replaced the hard and soft line (cause I could) and kept more money for the machine work.
That said, any type of cooling for the transmission lines is a good thing. Heat is evil.
Looks like something you might want for H.D. towing, but for location in 80 - somewhere it's protected. but will let fan cool it - guess we'd really need some dimensions.
Edit: Oh, didn't see the link:7.5"X12"X3.125". Remember, the more exposed lines you have, the bigger chance you have of snagging one off in the brush. Prolly somewhere fairly high to protect it.
Personally, I think the OEM cooler is adequate for the job. ...
X2 the US rigs with the towing option work very well, even when stressed in desert climate. My guess is the factory cooler is much more efficient than that one. The general rule with coolers is cross flow plate type coolers (like the stock one) are most always more efficient than tube type and surface area is very important, wider, taller and thinner are always good things. So that is a less efficient design with less area, IMHO it would reduce cooling when compared to the stock setup.
Like everyone else has said, Paul, it's not needed in your '94. Plus the one in your picture doesn't even do a good job of cooling - much less efficient than the cross flow style.
