Transmission Conversion Dilemma
The restoration on my FJ has begun. I've torn the interior down and took off the front clip. My intentiorns are a frame down restoration.
Here's my probelm. I FJ has a solid 350 with the stock 3 speed trainsmission. When the conversion was done for the engine, the motor mounts were welded in so it will be a real PITA to move the motor for a 5 speed.
Nevertheless, do you guys think I should proceed with a 5 speed transmission conversion or keep the stock three speed in? It's a tremoundous amount of work to add the 5 speed and I'm wondering if the stock trasmission is cabable enough for the long haul.
My intetions are to use the FJ as a city cruiser and the ocassional off road trip. Mostly, I'll be drinving it in the city as a second vehicle.
Let me know your thoughs.
restoration and 350 not go togeather at all, it you want a restoration get a 145F and be done with it, if you want a 350 do what ever you want, but the 3 speed is not the strong and wont last long behind a 350
Yeah restoration implies returning to EXACTLY stock condition. Not really that fun IMO. But a frame off "fixing up" is much more my style too.
I'd prefer the 5 speed or an automatic, and I weld, so moving the mounts wouldn't be that big a deal I don't think. Maybe an extra couple of days, but that in the scope of what your are up to is just not that much. The only hard part I think would be figuring the best place to relocate the engine to. But again that is totally different if you don't do your own welding.
The three speed can hang for a long time, but a deeper first and an overdrive will make driving it a much better experiance overall.
If you don't already weld, get a Harbour frieght 240 volt welder, all the sizes of wire and contact tips that it accomadates, read a book, and start burning metal. It will make such a huge differance once you get comfortable with it and you will be able to make so many little mods here and there that you never even realized you wanted to do. When you need to move something just an inch or two you'll just cut it off and move it without a second thought.
