Transfercase shims...how many
ravenna Mi sittin 10 deep.
Open up the tc on my 95' to do the pt kit. From watching the vid on YouTube it's showing a thick the thin shim for the bearing pre-load...but when I opened mine up I only have one thick one. Went to dealership this morning to see what I could find out. Nothing. New to the 80's... first time into one of these cases. What says the board....one or two? Thank a ton.
Each transfer case will be shimmed per transfer case from Aisin during manufacture. Just because one transfer case as a thick shim and a thin shim does not mean each transfer case will be that way. Shims adjust for manufacturing deviance during housing case casting/machining.
Read FSM and measure shim that came on there. Then cross reference to the shim list in the FSM. As needed, replace shim with needed depth based on parts list.
Your dealership drones will be useless in something like this.
List you need will be based on these thicknesses. In most cases, you are able to reuse what was in there. Most. Some not so much.
Thanks a ton. Kinda confirmed what I was thinking. Someone had been in there before...and I simple don't trust people to put things back together. Ya know....
I beat myself up about just putting it back together...but had to do some research. Won't do it half ass. I'm keeping the truck and plan on many miles.....
Thank again...really was a pretty basic job. Nothing really hard as long as ya got the right tools. A impact gun and a bearing separator.
The red silicone around the edges. It had a bad viscous coupler going on... not sure if they were in there trying to figure that out or not.
