Transfercase operational question
Trying to adjust to North DFW
Stayed up all night putting a spool and some bearings in the transfercase. I finished up things this morning, although I haven't taken the first drive. I noticed that while the transfercase is in neutral and transmission is in gear, I've got a nice gear grind. Is this normal?
  • shifts a tad firmer
  • no other abnormal noises while moved around the driveway
Audible whirring isn't unusual with transfer cases in neutral in my experience. I haven't tried the 80's like that now that you mention it. However, if it's a noticeable gear grind, I think you may have an issue.
Might possibly be a linkage issue, say maybe the lever in neutral leaves the engagement just missing the end of the next gear, making that noise? But with changing bearings, it could be a matter of how things were set-up I suppose, as that could cause a similar effect depending on shaft end play and the possibility for a bearing to maybe not be fully seated on its shaft.
There should no noise at all with the transfer in neutral, something binding up there. Remember you are 'between' gears. I would try a few shifts between low and high on the transfer, feel for sloppiness in the shift, either way it should be quiet.
regards
Dave
The thought just occurred to me that there's something else potentially not right here. You normally have to be in Neutral with the Transmission to shift into Neutral on the transfer case. Normally, you would only shift into gear when in N with the TC to run the PTO. North American spec transfer cases don't have the port and cover where the PTO unit bolts on, so if you're in the US, etc, you need not worry about this. If you're someplace where the PTO is available and if you are equipped with it, that could be a factor here.
Mike, Dave, Thanks for the fast response.
Dave, you confirmed my fear. Mike, you're not wrong but I was shifting through the gears to confirm the proper operation. I think Dave's suspicion is a good lead. When I put this bearing plate on (picture below) I recall thinking I wonder if the shims are alinged and pressing the bearing plates inward when I tightened the plate. Well, I just took the center diff retainer plate off again and the shims fell out. I'm hoping I can tap the race in with a brass drift.
I believe you have found the issue, as that certainly sounds as if the shims not being fully seated/correctly in place were keeping the bearing plate from allowing proper clearance. Good luck on the drift and a square smack or two getting the race nestled down tight.
