The conversion is fairly simple. here is what you need to go get as stated above.
1) rear input shaft bearing. The bearing you want to get is from a Datsun B210 rear wheel/axle bearing. Just go to Napa and tell them that. It cost me 50.00 bucks but it took a day or two cause they had to order it.
2) You will either need a spacer or the PTO gear for the 4spd tranny(the 4spd tranny should have one or the other in there.
3) the correct bolts (IE either the 3spd bolts or the 4spd bolts) for attaching the transfer case to the trannsmisson...i forgot(hehe) which bolts that i used when i did mine...i had both sets so i just used the ones that worked.
4) You will have to addjust your 4spd shifter linkage to fit the 3spd case...IE the actuator that goes in an out on the nose cone is to short on the 3spd transfer to reach the 4sp linkage so you will have to extend it or you can swap out the 4spd for the 3spd nose cone rod thingy(thats what i did but i had mine all apart)
5) Drive shaft flanges/parking brake...the 3spd and 4spd D-shaft flanges have diffrent bolt patterns...so you can either swap out the flanges on the Tcase for the ones from the 4 spd OR you can get the transfer case end of the 3spd drive shaft and slip that on your 4 spd drive shaft...the splines are the same...you will have a hybrid driveshaft then. 4spd at the Diff end and 3spd at the transfer case end...should be no biggy. I chose to swich out my flanges because i was rebuild the case anyway.
Stew...
