transfer case u-joint bolts stuck
Woody P
I need to get the short end of the rear driveshaft off from the transfer case side, and the bolts that are on there now are stuck. I don't want to end up stripping them and certianly don't want to bend anything inside the transfer case ( if that is even possible).
I know a lot of you have removed the entire rear driveshaft, any suggestions on getting the transfer case side unbolted?
Is it possible to bend anything, like the rear drive output shaft in the transfer case by putting too much torque on the bolts when trying to remove them? Right now I have the axel side off, should I put it back on when trying to get the transfer case side? It is in gear to prevent it from spinning. Thanks guys.
Aren't they nuts? (they are on my 3 speeds)
Soak them in PB blaster or Kroil for a day or two.
and heat, and my gorilla neighbor, still wont even budge.
I need to get this thing off because the driveshaft shop welded the splined section of the propeller shaft 1/2 a spline off so it won't marry up to the short section and be in phase. This will be the third trip to the shop for this gd thing so I want to make sure it is the last. Stupid F'ing bolts!
1phrogguy said:
not on mine, its a split transfer from a 60. It has round heads on the transfer case side and the nuts on the rear end side. Already hit em with wd40.
Pretty sure those round headed bolts are studs unless someone did some sort of modification. You should only need to turn the nuts on the driveshaft side. The "bolts" should not turn. They basically are like small wheel studs that are pressed into the transfercase output flange.
Mike
You need to use a penetrating oil. wd40 was developed to displace water, not break down metal oxides.
Finally got them off using some penetrating oil and an impact wrench. What a PITA!
Miker, you are absolutely right, as soon as I got it loose I said hey those things look just like wheel studs. Now just need to get the shaft in phase.
