Transfer Case switch part #
Los Angeles
Hi everyone
While getting some work done on the rig at a Toyota dealership, I asked them to swap out the two original Transfer Case switches with the ones I just bought (Beck Arnley, part # 201-1788). The shop foreman said, only the front transfer case was the right fit, but the REAR is different. Is that so? In my research on this forum, I didn't read that the rear one is different. I thought the switches are the same for both front and rear transfer cases. Can someone confirm, and if different, could someone kindly provide me with a part number from an aftermarket source? Here is what I have........this doesn't fit the rear transfer case:
Much thanks.
Funny, I found the same problem with mine. I have a 93 fzj80, and the 4 lo switch is different. Give me some time to look and I will send you the part number for the rear switch.
Much obliged for taking the trouble to find the part number, KFIRE01. Would that be a Toyota part?
I will try reviving the original one first, before getting a replacement.
