Transfer case support arm
So as some of you know, I bought a '96 80 a few weeks back and have been discovering some surprises that the PO failed to mention. Anyway, while in the process of removing the locked up VC, I noticed that the support arm that runs from the frame to the T/C (transfer case) is missing.
I plan to fab one up today and probably tie in a T/C skid plate but I wanted to get a good look at what the factory arm looks like first.
Can someone provide a picture of this arm? Thanks
Update: Looking at the picture in VC removal thread, it appears that he doesn't have an arm either. I'm assuming there should be an arm there or else I don't see the point of having the rubber block. I also don't think it's designed to have all the weight hanging off the back of the tranny and nothing to support it from rotational forces. I'm assuming that the poster of the VC removal thread is either missing his arm or took it off prior to the photo.
Picture would help.
But if it's the rubber block I'm thinking of, my 96 and 97 LX's don't have one either.
Ya talkin' to me? :)
No, I have both arms and they are not detachable. I was holding the camera in both arms and this is why they are not visible :flipoff2:
But seriously, there is not support arm in the position of the rubber block. The frame has a support arm where the tranny connects to the t-case (it is visible in my pics of the viscous coupler removal). I've just checked in EPC that my frame is complete.
So don't worry, you have all the arms you need. This big rubber block is probably to dampen vibrations.
Oh, and here goes the pic...
Haha, I like the humor, that was pretty good.
I'll have to crawl back under and look again, it still seems to me that there should be some kind of support farther back though. I wonder why they didn't design it like that?
I'm a Samurai owner too and those trucks are notorious for being the TCase support arms....that's why I figured the LC had to have something a little farther back than just where the Tcase and transmission mate together.
I never put another VC. I really don't see the need to do it and I didn't think about it either. When I'm on the road I don't need a VC anyway. On slippery surfaces I simply switch on the center diff lock. Once I go to low range the center diff lock is automatically engaged so the VC is not needed. The VC could be helpful in a situation where one needs to accelerate on a surface with slippery patches (sand, ice patches) but this is really a rare occurrence. I tried to cut my VC apart but the steel it's made of is really hard. A real pain. Now I have a plasma cutter so maybe I will open it up tomorrow.
