Transfer case stick buzzing
Kamloops, BC
My transfer case stick started buzzing the other day. I talked to Tony at Altoy in Kamloops here, he said it is a common problem. He has seen lots of LCs with rubber straps and other "shock absorbing" setups to stop the stick from vibrating. Does anyone have a fix for this and/or the reason why it buzzes?:beer:
Neither of mine vibrate.
What are they buzzing against?
If I have a pen or some nic-nak junk sitting in the boot that surrounds the T-case I get a bit of buzzing. However, it is not audible if I remove the junk from the vicinity.
Edit: Mine buzzes under low end acceleration with only when I have junk near it.
Is the buzzing on acceleration? Deceleration? Cruising? Checked your TC fluid level lately?
John
My 45 TC stick has a buzz. I put a glove over the stick and that helped for several years. I guess now I will have to climb under the truck and tighten or replace the bushings on the linkage.
May be the same problem on an 80.
John
It happens while accelerating and cruising, transfer case fluid level is perfect, I do have quite a bit of junk collecting around the stick boot, sounds like I will have to crawl around under the truck to check the linkage for bushings that may be worn.
If you figure out how to get to them, let me know.
From what I saw in the FSM (and crawling under the truck) the linkages sit on top of the t-case. Even with my 1" body lift, there is *VERY* little room to get up in there.
(Unlike the transmission linkages, which are extremely easy to get to.)
I guess I have to ponder how much the buzzing bothers me wish I could find a FSM.
Another buzzer here. Mine has high frequency vibrations (like from gear mesh, not road vibrations), and makes slight noise above 60mph or so. Seems like it's always going to vibrate, I plan to remove the trim cover and see where the contact is being made to create the noise so I can try to solve the problem.
I figured all the transfer cases did this - maybe it's only wishful thinking!
