Transfer Case Skidplate
Tonight I found the time to put in some work on my transfer case skidplate, although I still have a bit more work to finish it.
For my skidplate, I was looking to build something that gave me both bottom and side protection, and was tied into the frame so that it wouldn't bend or smack the T-case the first time I slid off a rock/ledge and landed on it. I haven't built the skidplate to frame arms yet but I've already got them figured out in my head. Hopefully I'll have enough time on Sunday to get them cut and drilled.
Once that's done, I'll cut off the excess angled vertical plate (a tiny bit is hanging down), grind on the bottom cutting slag a bit more to smooth the rough edges, throw some rustoleum paint on it, and bolt it up.
What I learned:
A) Next time I would probably just use a flat plate with a strategically placed support arm to give me enough "bow" to clear the bottom-most part transfer case. The angles give a few style points but for ease of fabrication, a flat plate would be best.
B) I need either a bench grinder or a stand for my 4.5" angle grinder so I gring the cutting torch slag easier.
C) When bending plate (this is 3/16") using the scribe method, cut from the middle outward and leave the ends connected. This keeps the metal from twisting when you bend it and leaving the ends out of line. This is hard to explain but if you ever do it, you'll know right away what I'm talking about.
As always, please share your thoughts!
PHOTOS!!
looks good! is it just bolted to the factory cross member? and what is keeping you from building your own cross member/skid all as one unit? i will eventually need to do something like this too. thanks for posting.
Yup, I just used the factory crossmember mouting holes and once I make the support arm, it will also bolt to the frame using an exisiting hole. As far as not making a full belly plate, I like it better this way because I can undue 3 bolts (4 in the future), if i need to check/drain the T-case, plus it's much lighter.
Honestly, I didn't see many pro's to making a full belly plate but to each his own:beer:
