Transfer case shift under dash Vs on floor???
Nunn Colorado
I was looking at a Fj40 earlier this week and noticed something interesting. The transfer case shifter was mounted under the dash between the heater and steering column. A pull type lever essentially. This FJ had the older style doors so I'm guessing it's pre 75/76. I have spent a fair amount of time around early 70's FJ's as well and never noticed this. So, is this late 60's option? Just curious.
Yes it is the way toyota did it before floor shifters became standard. Tranny shifter on the steering column and transfer case on the dash.
My 70 still has the low range lever under the dash. It can some times be a nuisance reaching under to pull it in to low but to push it back in I often us my foot. It originally had a sliding switch on the lever that worked a vacuum switch that engaged the front drive shaft I removed the sliding switch so I could use low range with out having to lock the hubs. I put a front drive lever on the floor.
The only problem 4X4veteran has when going into 2WD Low Range is he has to really respect the gas pedal since he just doubled the power to the rear rind & pinion gears.
Story about the under-dash low range lever: A newbie rolled his rig after running out of power during a steep hill climb. We asked him if he had engaged low range, pointing to his under-dash low range lever. He stated "I thought that was to open a vent".
early 40/45's it was on the dash, then moved to below the dash, I like it on the dash
I wouldn't call it a problem but you have a point about power to just the rear wheels. When pulling heavy loads on a trailer the extra low gears are nice for take off. Just have to watch that I don't over rev it.
It was moved to under the dash in the US with the 68 model and the padded dash. Have both the under the dash and on the dash and prefer the under dash. I reluctantly moved the high/low shifter to the floor in my 68 when I replaced the single lower dash to the two piece and cut the dash to put in a radio in the location it is on the 73+ models. A rod runs in the back of the dash in that location preventing the LHD under dash shifter with a radio. My 70 still has the stock setup and when I bought it I adjusted all the linkage and replaced the switch that operates the 4WD light on the dash. Everything work faultlessly. A lot less sluggish than the vacuum operated 4WD in the FJ62.
I use to use 2WD low range when pulling my boat up a steep boat ramp where the tires were on concrete and getting good traction, just needed the extra power.
