Cruisin'
Out in the shop, building something cool!
After wheeling last weekend my transfer case rear seal has sprouted a leak. I found a thread in the 80 section on replacing the seal, but it applied to the NA spec trucks with the viscous coupler. Since my truck doesn't have that, and I presume not the extra housing on the rear of the transfer case either, would replacing the seal simply involve dropping the drive shaft and pulling the output shaft (like doing a pinion seal on a rear diff)? Also, the dealer said he could get me the seal in a day, but now I'm not sure if it would be the same seal.
Does anybody have experience with this? A brief description of the procedure and even a part number would be super helpful.
The other thing I wondered is if a clogged breather might be pressurizing the t-case and pushing fluid out of the seal. I'll check out that possibility tonight. Any thoughts?
Cheers
Cheers
