Transfer Case question
One piece case has a rear output shaft that remains 'coarse' through the production run...
One piece case has a front output shaft that in 1978 went from coarse spline, same as the pinion in the diff, to fine spline(26, iirc) and then was that way until the final one piece case was installed in a Land Cruiser in 07/80....
Hey thanks Poser. Do the later split cases have the same style as a 76? Or do they use a different style flange?
My question comes from a 76 fj40 with fj60 trans/TC. The front output flange on the TC is FUBAR. I'm just trying to figure out which one get.
-Duane
yotanut said:
Do the later split cases have the same style as a 76? Or do they use a different style flange? My question comes from a 76 fj40 with fj60 trans/TC. The front output flange on the TC is FUBAR. I'm just trying to figure out which one get.
-Duane
The 60 series transfer case will have one of two front output companion flanges, depending on the year of the trans and transfer case combo, the difference being the bolt pattern on the flange….The pre 08/84 companion flange will have a bolt pattern that was the same as the 40/55 series from 01/74 until 07/84, the wider pattern was used on the 08/84 and later drive shaft companion flanges. IIRC, you will need to source a front output flange from a split case, as the earlier one piece transfer case flanges are not compatible with the front output shaft on the split case.
Good luck!
-Steve
