Transfer case problem!
Dallas
Website
www.octagonmma.com
I got my tranny/tcase back from the mechanic and look at what I found! Is this an issue and can I fix it? The bolt end is snapped off clean. Any suggestions? I can probably file it down and put a nut on it, but is that sufficient? The bracket gate for that transfer shiftlever holds it tight up on the tranny case, but I don't feel like having the lower arm pop off and disengage the front axle if I really need it.
I also got the units back with all this hardware. What the hell do I do with it? I think the copper washers are crush rings for the filler holes plugs. What about the o-rings and other stuff? They ignored a few of the paper gaskets and used black expoxy looking stuff instead. Leftovers from the cruiseroutfitters kit, but should they have used some of this stuff?
Many of the gasket kits are generic and have pieces in them applicable to a wide range of years, which means that there will be leftovers in some instances.
Replace the shifter pivot.
Yes you can handle it.
Take a lot of pictures of it so that you can put it back together correctly. ;)
Good luck!
-Steve
Do I have a place to order from? CDan?
