transfer case options
Seattle
I am thinking about next winter already. Actually, I am thinking about the next mod for next winter.
This is going in a 73 FJ40. SBC, SOA, 4WDB, 55 rear springs, 37" MTR's. (I am just finishing the SOA this winter).
This will be my daily driver (why build it if you can't play in it?) >10 miles a day, but it 60 miles to the nearest wheeling hole. The goal is to make this a as capable and as comfortable as possible. I would like to keep the 4.10s, they are nice on the freeway.
So these are the options I am concidering:
1)SM465/Toybox (4.7 ratio)/3sp tcase with saver
pro- tons of gear options
con- length/ weak tcase
2)SM465/Orion (4.0 ratio)
pro- simplish operation
con- limited gears
3)TH350/Orion (4.0 ratio)
pro- super control
con- $$$$/length/less simple mod
Please share your thoughts on these options. Thanks
Andy
I have, they are a little harder to come by for the money I can get a 465 or a 350 for. I am not sure the 5th gear is worth the extra $$.
The hope to keep the cost under $2000. I picked up a 465 on the cheap and the three speed is stock. Using one or both of those will save some $$. I am not necessarily stuck on either one though.
This would not be the desirable setup, at least not with a three-speed transfer case. Installing almost a 5:1 behind a 6.5:1 and running that through a stock case would just be asking for issues. Other than the strength issue with the narrower gears, the case, even with a saver, would not be as strong as a later four-speed transfer case and a saver. The gear set in the four-speed case would be stronger also. The difference lost between the 1.99 and the 2.313 is something that will only show up on paper, and is not something that I would spend a penny on in the attempt to “increase my crawl ratio”. This would not be any simpler of an install over an auto and a stock or Orion case. What good is it to pay for a pile of gearing options that you will hardly, if ever, use, unless you are going for novelty.
con- limited gears
With this combination, you talk about “limited gears”, which really makes me laugh. How much time do you have behind the wheel operating a Land Cruiser with a 465 and a three or four-speed transfer case? If you are really concerned about gearing options, install a 2.8:1 Toybox in front of a stock case, and when it breaks, because it will, perhaps you can find one of those 4:1 Orion’s laying around that so many people dislike because of the “limited gearing options” they have provide.
I have built, and spent a considerable amount of time operating, a 2F/465/2.8:1Toybox/Orion and 5.29 R&P, 38.5 SX Swamper equipped 40 series. The crawl ratio provided by this combination is over 300:1. While it is really neat, the practical application of that ratio in a vehicle with an engine that produces a lot of torque at low rpm’s is all but nil. It might be different if you had a sewing machine motor for a power plant, but you do not.
pro- super control
By far, this would be the best “daily driver” option, and you would likely enjoy operating the truck more both on and off road. Considering the modifications that would need to take place to use a 465/Toybox/and ? case, and the fact that you are already going to be moving the rear axle rearward, or really should be thinking hard about stretching the wheelbase, it would make any of these longer drive train modifications fit easier, able to run at highway speed and not rattle your fillings out of your skull, and the on-highway ride will improve with a longer wheelbase, as will your climbing ability off road.
There is not a cheap option with any of these really, so I guess I would read up as much as you can on the many drive train combos that are in use out here and other places, and decide what you want based off of that info. Do not be afraid to read some things that Jeep guys have done too, as much of this crosses over in one way or another.
Good luck!
-Steve
great points poser, I have driven treeroots 78 (2F465/orion) offroad and his 100 some : 1 is more than plenty even behind a dead engine. I personally feel like the gears in that setup are spaced very well, I couldn't really imagine needing more choices. Not to mention how short this setup is also.
I personally have been very very pleased with my F/420/3speed especially for the amount of $$ I have in it. I really think it was the best thing done to my cruiser next to lockers. It has been pretty much as low as needed, i do slip my clutch just a little on some vert stuff. So that leaves me lusting for an orion or atlas :D
do not forget power steering man...that was the first mod I did...the 420 came after the 4wdb.... :beer: It all goes hand in hand :beer:
I just installed a sm420/ toybox 2.28/ split case in my rig, I must say it is a dream around town and on the freeway, but stop and go rushhour isnot so much fun (the 420 is a wide ratio slow shifting beast!) The split case is quiet and shifts easy and this combo gives me 150:1 in the rocks. I have moved my rear axle back 1.5" so I have a 21" rear driveline using a mini CV so all and all I am real happy with this latest version of my rig!
-Scott
Thanks for the thoughts. Poser, good points.
I did move ther rear housing back about 3 inches with the 55 springs. I will have about 98" of wheelbase now.
My experience is limited to a stock 76 FJ40 and 31's. This 73 FJ40 with V8 and the stock 3 speed tranny and t/case. Both in my opinion are under geared.
I would like to end up about 150:1 at the low range.
Hi All:
Andy, like I said last night, I think the SM465 and an Orion t-case will be pretty darn good combo in your rig; relatively easy install, it is "portable" (meaning it can be easily moved from rig to rig), and nets you gearing of almost 107 to 1 with 4.1 ratio diffs!
For all the problems that folks have had with the Orion, it is an easier, cleaner install than any "doubler" type gearbox, and AA has finally gotten the "bugs" figured out.
Anyhow, looking forward to getting out on the trai lwith you this year!
Best,
Alan
Seattle
