hi, I have an 86 fj60 w/ 211k that’s leaks gear oil from the top of the t-case, it leaks a good amount after it's been parked for a while, I’ve tried my best to locate the leak as best as I can but I can't seem to trace it past the top because it is soo gunked up , I’m wonder if it’s a clogged up breather from the t/case or tranny that’s causing it to leak because it seems to only do it after driving it or its its the infamous seal between the t/case and tranny, any of you guys had similar problem like this? Any help is appreciated thanks.
