transfer case installation
mckinney
Just had the t-case for my cruiser rebuilt. Any help or pointers about reinstallation. It is a 76 fj40 and we removed the transfer case and transmission together. Someone has mentioned about lining up starter boltsl;l...... I am somewhat mechanically challenged so this is probaly not a great rig for me but I am excited about working on it.
Thanks.
Poser's suggestion is pictured below. Just longer bolts with the heads cut off, rounded and a slot cut in them for removal. There are pins on the bellhousing, but the longer "guide" bolts help to align it. I think you want the T/TC in 4th gear and high range so you can twist the outpur flange on the TC to help align the splines. Put in the other two transmission bolts and remove the guide bolts, etc, etc.
Ed
I pull the trans tunnel, and use an engine hoist and straps to lift the trans/tranny up off the floor and into place. The longer "dead" bolts or threaded rod is really helpful. If you can't do that, have a ruler handy, and measure the gap b/t trans and bellhouse on both sides as you slide together.
This can be frustrating to line up the trans input splines with the clutch disc, and then the pilot bearing. Take your time, you'll be alright.
If you have a front hoop on your roll cage and the top off it's easy. I installed my transmission/box/Orion combo by myself in less than a half hour. A 4X4 across two cage hoops and a $40 chain hoist from Harbor frieght did the trick. Click the images to see full size.
One of the guys in our club told me about this.
you people are great. Really glad that I discovered this board.
Seems to be a large amount of knowledge floating around on here.
Also Missisboy, do you know where Senatobia and Sarah Mississippi are. ? I have quite a few relatives there and was actually born in the area myself.
yup, sure do. my grandfather, "buck graves" lived in sarah, until he passed a few years back. my cousin now lives in his house. it's only about 10 or 15 minutes from tunica, which is where i live. senetobia is about 25 miles east of tunica. where were you born?
