transfer case identification
south eastern idaho
man i cant seem to catch a brake here lol. google and forum searched and cant find the info i need. my outputshaft seal for the rear driveline is leaking . vato zone gave me a list of 4 different xfer case's that came in my year truck all with different seals of course. there are no visible tags on my case. does anyone know how to identify which xfer case i have? 90 dx 5 speed with the v6 if that helps
Punch your VIN into toyodiy.com and pull the Yota part number. Putting in your VIN will drill down to the sub model of your truck and give you a part number for your truck.
What tranny do you have? You can get that off your data plate under the hood
IIRC, the 5-speed manual box that came with the V6 was the R150F, which should have the RF1A transfer case which I think has a 7-bolt cover.
There are a few other combos out there but the above is the most common I think. I'm sure you could dig the info up on the interwebz once you verify the gearbox you have.
Very simple. Call Sam or Onur (beno) with your VIN. They will mail you the correct OEM part that will fit. Don't forget to also get a new stake nut for the shaft.
