('95 FZJ80 with lockers) I was just going through the motions of baselining all of the driveline fluids (should have done this a couple of thousand miles ago when I first bought the truck), and I ran across something puzzling. Drained the green molasses (no kidding, the thickest gear oil I've ever seen) out of the front diff. and replaced it with Mobil 1 75W-90. Then, when I pulled the t-case plug..........what came out was ATF! WTF? I read the manual before I started this process, and the t-case clearly calls for 75W-90 gear oil. Then I came here to MUD to make sure there weren't others who were using ATF in place of gear oil, but none found. Heck, I even climbed back under the truck to make sure I had drained the t-case instead of the transmission, but thankfully, I wasn't that absent minded (this time anyway).........In any event, were there ANY 80 LC transfer cases that used ATF in the place of gear oil?
I'm going to go back with the 75W-90 the manual calls for, but if I'm wrong for some reason, someone please let me know.
Thanks in advance.
Thanks in advance.
