trans to radiator lines help
Kentucky
I bought a 1996 L/C that had bee tore apart before i got it. This is my first L/C, It looks to have a new radiator it had been sitting since 2009. where the trans cooler lines screw onto the radiator won't tighten up the fittings don't look stripped the ends from the hose look to be the factory ones and were only hand tight. I looked for a fitting in some parts drawings that i may be missing but found nothing. I was wondering if the aftermarket radiators have a different thread. any help would be appreciated. Thank you
Typically if the fittings won't tighten up something is stripped. If the thread pitch is off then it will be very difficult to mate and will only spin on less than 1/4 turn before becoming too tight to turn by hand.
If it's an aftermarket radiator, does it have METRIC trans cooler threads or does it have NPT threads? They are NOT the same.
Can you identify the radiator make and model?
$400 and you can have a new OEM one in it and stop screwing around with it.
Exactly what Bilt4me said. I just replaced mine with an aftermarket version and the brass nozzles do not screw into the OEM radiator threads and visa versa Mine were a bit of a pain as they can loosen off very easy. What i did was tighten them up finger tight then using the 'L' shape angle of their design just reefed them tight by hand and all fixed. I used a wrench initially and it wasnt enough strangely. If you arent careful you can lose a bit of trans fluid so make sure they are tight as you can get by hand, you can even get under the truck with the bash plate off without removing anything else.
Did the after market one come with a set of the fittings. The radiator side looks like 30" JIC the tube part is 10mm and ID of threads is 12.5-13mm.
Yeh they come with the radiator just check before you buy. Do not buy a plastic top tank rad as they will fail Instantly or very early on with an 80 (in my exp anyway)
Unless you buy an OEM radiator. My first one lasted 18 years. It was a perfect drop-in fit. Even came with a new radiator cap (also OEM).
Again, it's about $400, but I won't have to screw with it for a LONG time.
Yeh my plastic top rad popped a leak within the first few hundred miles of installation . Never again only Oem or brass Koyo for me
