Trans or Aussie Locker problem?
Fairfax, VA
I recently changed gear ratios and added a Aussie Locker to the rear. Ive read all about the every now and again clunk from the Aussies. Well today Im cruising down the highway about 70, when something feels a little funny for a second or two, I look at my gauge cluster and see my rpm's are way high(4500-5000) and my speedo is reading about 100 mph, but Im actually going 65-70. Im thinking what the hell, well I let off the gas and then I hear/feel clunk in rear and I hear tire chirp. Then everything is back to normal. Meanwhile Im still going about 65, this all happened in 2-3 seconds. The only comparison I can make is if you were spinning your tires on ice, and then it caught traction. The Aussie and gears were set to spec. I recently adjusted my throttle cable for kickdown, and that has been great, it also is in spec. Anyone have any ideas? I hope Im not looking at a replacement trans!!!!! My rig only has 150k.
Thanks
:cheers:
I ve been following your threads. Im looking ti regear my 3FE to 4.56 or 4.88 and adding a Aussie. Good luck hope it was a fluke.
Thanks
:cheers:
Sounds more like something not right with Aussie locker. Your speedo was showing 100MPH and you heard clunk when you removed power from drive train. It would be probably worth to look at Aussie in case something is not sitting right. Better to be safe then have differential go bust on you.
I think I will go back and check the throttle cable, thats the only thing I can think it would be.
Update, I removed rear diff cover to check Aussie and everything else, Aussie looked fine. I could rotate tires and watch locker engage and disengage. I then replaced gear oil with new and went on to check tranny level. Trans level was good, just had it changed last year. Im running out of ideas?
Speedo cable is attached to the trans. Im no auto trans expert but sounds like your trans is slipping because your clutches are worn. New trans needed if thats the case. Had an old benz with same problems. Hear any grinding sounds?
BTW, sucks to hear this. I got a '92 w/147K.
I really doubt that your tranny is going out at only 150k. I have over 190,000 on mine and recently adjusted my cable and haven't had any trouble. I am confused by this though, I would keep looking into the aussie. It could look right, but still have problems. Are there any shops who would know what they're doing with an aussie rear end? Hope it works out, I too have been following this.
The speedo cable is connected to the transfer, geared off of the rear drive shaft output. If the trans slipped the motor would rev, tach go up, but the speedo wouldn't be affected. Id don't see how it could be a trans or transfer problem?
I've been mulling this one over in my mind and come to the conclusion that it is in your rear diff with the Aussie. You've changed gears in both 3rd members, right? And being a '91 you got no VC in the T/C so if the rear diff starts slipping, for some reason at say 70 mph, the engine, tranny and T/C would interpret that as no traction, giving all torque to the slipping diff, upping the speed and rpm at the same time, as you experienced. When you let off the throttle, torque to diffs stopped and allowed Aussie to do something different causing the tire chirp. Then, as you say, all returned to normal. If it were me, I'd yank out the Aussie as a new defective and have them give you another. I'd say you're lucky you don't have a diff full of metal chips right now, at the least or worst have it seize up on you and put you and your 80 in a ditch. My .02
80t0ylc ,
Those are my same thoughts, I have only done the rear gears, I have not done the front yet. So now my front drive shaft is out and CDL is locked. I have front gears but waiting till it warms up a bit. I think I am gonna put my spider gears back in and drive it a while and see what it does. Trans is definitely not slipping. Im leaning mor towards the rear, is it possible Center Diff Lock is disengaging for a split second and then locking back up. Im gonna shoot Aussie a email and see if they have any ideas.
Thanks
80t0ylc ,
Thanks
I doubt it. I don't think you'd have got the tire chirp you experienced if the CDL unlocked and than locked up again.
Here are some things i see may be going on hope it helps?
When a locker like a AUSSIE, lockright or Detroit are used in 2wd NO front power to the axle you will get allot more noise from the locker period, if it slips and makes a banging noise in like striping teeth and catches as you accelerate down a straight line you may have a bad locker or out of spec components that are incompatible
if your tires are not the same pressure or the exact same size with a tape measure you will feel a sway and possible bang and chirp from the tire during loading and unloading the locker.
The locker locks under load from the input of power,this same principle apply on the gas and under deceleration.
When you have power applied it will be in lock up,when you let off the gas it will go to semi unlock and if there is any difference any where in tire size or axle squareness it will unlock and let the bind unload and let the truck sway/jerk maybe Bang (if you drop off the gas fast) , next it will start getting input deceleration power and find its way to lock back in,that's when the bind starts again and if its great enough it will bang as it locks and loads and maybe chirp the tires ...
I have no idea how that can make your Speedo go crazy ?
.in rear wheel drive (2wd) it is common to have some noise and chirps here and there with a full time locker.
Aussie Locker
Based on what we have read here we feel that the problem is in the transmission. The only way to get slippage in the rear locker, under power, would be if the interlocking gear teeth on both sides of the locker had been ground down to almost nothing and ground down evenly. When the rear end was checked there were no broken parts and when the spin test was conducted and it worked properly, that pretty well eliminated the locker from consideration based on the available information.
The tach reading also supports a transmission issue. A clunk sound could well have been the driveline taking pressure away from the rearend and the tire chirp would have come when the clutches were trying to engage at such a high rpm.
If the problem were the locker being worn out due to the teeth being ground down to point of slipping then the problem would be visually obvious and would get worse quickly.
If you have any other input or questions please contact us at engineering@aussielocker.com
Has the problem only occurred once? If so, is it at all possible it was loss of traction with both tires on black ice?
Where does the speedo feed off of at the center diff? Is it off the rear output? Or is it off the input (i.e. where rpms could increase if the front output was spinning free?)? If it's possible for the CDL to disengage, then re-engage when front-rear speed match as the engine speed drops, I'm sure you would get chirp as tire rotation suddenly engages with powertrain rotation. Knowing where the speedo feeds off of is key in eliminating the possibility of the problem being forward of the rear driveshaft.
Of course I don't have an Aussie yet, and don't know the AWD system, so all this is speculation.
Aussie Locker,
Can the Aussie Locker unlock both side gears at the same time itself under light to little load, then applying load back causing it to lock back up? Thanks
Aussie Locker,
When the vehicle is going straight on the road, as we understand was the case in this instance, the locker is always locked unless one wheel attemps to overdrive the speed of the driveline and at that point that and only that wheel would disengage. We do not see a situation where as long as there is drive to the differential that the Aussie Locker would unlock both sides even under light load.
The speedo drive gear is on the transfer rear output shaft, senses rear drive shaft speed.
The high speedo reading eliminates trans/transfer, if it were a trans slip the tach would rise and speedo stay normal.
Agreed, axle and drive shaft parts usually don't slip and heal them self, most times slip = broken, no drive.:confused:
True but thats assuming everything is installed in right places. You can make those teeths slip if you
a. Install locker with no springs
b. Install locker with tons of grease on teeths (that will not last long as grease will get pumped out but
