Trans help - feeling cursed...
No codes recently. PO136, PO115 a while back - replaced an 02 sensor a few weeks ago, CEL hasn't popped back up yet.
What if a front drive flange (that thing that has six 10mm bolts at the centre of the front wheel under the centre cap) ) is stripped and the winding up you feel is the vsc kicking in?
Thanks, and I really do apologize for my lack of knowledge here (starting to feel like a real schmuck) - but how would I visually inspect the front drive flanges for slippage? And what is the vsc?
New to all this; just trying to learn as quick as possible to keep my rig alive and the :princess: unconcerned...
I am having the same problem with my LC that I just purchased. I am going to try the screen clean & flush first.
'92 FJ80, BFG AT 31 10 50's, Alpine ?, aftermarket rock sliders.
Keep me posted if the flush/screen clean helps. I'll be doing the same when I get a free weekend - figure it's the logical (and cheapest) place to start. Wish I was more optimistic that it's gonna help though...
screen clean and flush isnt a miracle cure. but at least you could see clues there. if your transmission vibrates, it might be the torque converter gone wrong or maybe bearing failure. sounds like you also have a slip because your rig forwards on high 2500+ rpm
Since it was mentioned as a possibility regarding my problem, I did the drive flange test today as discussed in the post "a440f trans help!"...
With the vehicle in D and the brake depressed, as I accelerated the front drive shaft turned in what seemed to be something like 10 degree intervals. Slip, catch, slip, catch and so on. Took the dust covers off the drive plates but could NOT see the same slippage at the hub...
Still plan on dropping the trans pan to see if there's anything noticeable in there when I drain the fluid, clean the screen and refill.
