trans cooler line ???
Temple Terrace, FL
Hello everyone. I am new here. Been looking for an 80 for a while. Stumbled upon a pretty clean 94 for a deal. Needs a few things. First off the trans cooler line was broken off where it goes into transmission and someone screwed a new fitting in with a 8 inch piece of brake line and s one make shift doubled up hoses. So my initial thought was to find a new line and replace. However I have pulled shifter and linkage and cannot figure out how its held in and also cannot find parts anywhere. Any suggestions? I have removed a mount on passenger side and one on driver side but the line seems to be stuck on top of transmission somewhere. No way to see or feel up there. Also where is everyone getting their oem parts from just the local toyota dealer? Thank you
No idea on your actual question about how the line is held in, but good luck on finding the actual fittings that go into the trans body. I had to buy both recently (no more info unless PM, gotta protect the perpetrator) and was told I got the last ones in the CONUS, none shown anywhere else. One of those fittings has a hole for the trans coolant temp sensor as well.
I wouldn't get too excited about not being able to find the actual lines themselves: some bulk line, a bender and a double-flair tool is your friend.
I don't know about the trans side but the cooler side uses two threaded nipples. Rather the threading goes to the cooler and the nipple side is for the hose. Mine got lost so I went to SOR to pick up a set. As for the lines you can just get bulk hose. I used AeroQuip hydraulic hose.
