Heres the scenario.
To try to get rid of the harsh shift when going from r to d I adjusted the throttle cable the other day. Seeing no mark under the red grommet I slacked it off a bit (undid the cable housing side 1/2 turn and tightened the cable/throttle body linkage side.
At first all was well and I didnt notice any difference in the way it shifted compared to before. Drove it around all day then stopped at the bus terminal to pickup, what else, more cruiser parts. I put it in reverse to back up out of the spot i was in and nothing. The engine just revved freely. Messed around a bit and all the forward gears were good but still no r. Pushed it put of the spot and drove home. When safely in the driveway I messed around again and managed to get r first try but had to release the brake pedal to get it to engage. From then on it was fine. Did more running around after that and when I get home I try r again and no go. Turned the van off then on again and gor r right away....
Im thinkin I need to tighten up that cable.
Ive also been hearing a hissing sound when in r for a couple months now. Same thing when in low gear but this is before I touched the cable.
Solenoid problems causing no r or dumbass messing the throttle cable tension. What do you say?
Thanks
D
Thanks
D
