So I attempted the tranny throttle cable adjustment here: 80-series Throttle Adjustment - Land Cruiser Tech from IH8MUD.com
I have all the symptoms described in the link above.
In doing so, I still have a lot of slack. Is it suppose to be tight when adjusted to the 1mm spec? Also, where and what on the transmission is this cable connected to? Are there any tension adjustments there?
Maybe I misinterpreted the parts on the diagram so could someone please label which part the end of the cable housing is and the which part the end of the stopper is. I don't think I have the end of the cable housing...all that's there is the black rubber boot that I guess is suppose to fit over the threads.
Thanks,
Slowleak
Thanks,
Slowleak
