- Joined
- Jul 15, 2004
- Threads
- 30
- Messages
- 167
If your 4WD shift arm on the T-case shifter won't reach it's notch after trhe swap, Mine was 1/2" shy. Pop the little button off the arm, it's pressed in, and tread it to 7/16-20 use a grade 8 bolt and jam nut and it will adjust were you need it. The 7/16 bolt head fits the notch perfect. Also someone asked about an SM465 with stock engine and no body lift awile back. It just fits, but your tunnel cover will need an EXTREM MAKEOVER.
