Tranny Noise
Humboldt Nation
OK, I've done some 'search' but didn't find anything similar.
I have a what I'd call a high pitch screeching noise when I put the trans in reverse.
I don't have the noise in drive or while moving forward in drive. The noise has been there on and off only in reverse(that I know of) for a while. The other day when I came off the beach I put it in reverse and got the noise and then pulled it down into 2nd and got a similar but different pitch screech. The noise in reverse, again, is intermittent as in doesn't always do it but when it happens it will do it moving in reverse or not moving.
The rig has almost 170K and the tranny fluid has been dumped(not flushed) several times since I've had it(1.5 years).
Hope I 'splained' it clearly.
Any ideas?
Thanks,
:cool:
Bump
Bump
I believe this is normal. I think it's just the normal play in the gearing and drivetrain re-adjusting. Happens on mine for as long as I can remember -
I'm not sure I'd consider the noise normal. I'm no mechanic, but what
'drivetrain re-adjusting' are you refering to?
thanks,
:cool:
Adjusting from park or neutral to reverse. I've had my truck since 56k mi, now at 109k, and I've heard the noise going into reverse for as long as I can remember. I'm no mechanic either and I'd say my noise is more like a creak or a squeeky hinge. Screeching to me implies something a bit more sustained. Mine is very brief.
This noise is sustained until I shift out of reverse.
:cool:
Bump
:frown:
Bump
Am I the only one?:confused:
:cool:
