Tranny Issues in the 80
Indianapolis
Website
www.expeditioncure.com
I searched and found some interesting stuff but nothing really sounded exactly like what is going on with my rig.
It's a 94 with 127,000 miles and the tranny was recently replaced. I checked the fluid and did the jumper test for the solenoids, they checked out fine.
When I put the truck in D and start out from a stand still the truck has problems shifting from 1st to 2nd. Once she shifts to 2nd everything resumes as normal. When the truck tries to shift from 1st to 2nd it shudders and the rev's shoot up and it seems as though the truck has loss of power. It will then eventually shift to 2nd and so on.
You can shift manually from L --> 2 --> D just fine.
Any ideas what to do next?
Thanks guys.
I don't know much about that old archaic bus transmission, ;) but that sounds exactly like the shift-solenoid problems that many have had with that transmission.
As I recall, replacing all (both ?) of the solenoids is relatively inexpensive and not difficult.
-B-
The tranny in my 93 had a few quirks when I got it. I adjusted the kick down cable and that took care of most of it, then I had a fluid exchange done and added mobil 1 synthetic, I could tell a difference running the syn. fluid, seems to go through the gears a little smoother.
Did you have the tranny replaced? Did the previous tranny have the same problems before it was replaced? Did you do the R&R of the tranny or a shop? I would not do anything yet. Post up the answers and lets do some thinking first. You may have other issues. What other info could you tell us about the tranny and the truck that you have not told us?
later Robbie
If you are dropping the pan just about 5. If doing an "exchange" 2 cases just to have plenty ie 24 on hand. May take less though, then you have some extra for next year when you just drain and refill.
If you had a 343 it may take 5 qts, with the 442 it is more like 7+ if you drop the pan and take out the screen(I would have on hand at least 9qts). I would check the solenoids with the FSM procedures(the computer may not fully give you what you need). Use the VOM and measure the resistance. I would guess that one of the solenoids is bad. It could be in the computer as well. that is why I asked the questions I did. Good luck with your project.
Bryan, if you haven't done so, you might try tightening your transmission throttle valve cable located on the back side of the throttle body. This will tighten your shift points up. This worked on my 92. 14mm wrench is all that's needed. Hope that helps.
