Tranny filter?
No, it's just a metal mesh which is supposed to trap bigger grit particles.
Theoretically you can replace anything, but in practice it's not a part you need to change/clean regularly. If you're not disassembling your tranny then you will never have to worry about it, but once you have dropped the pan to do anything in there it's a good idea to clean it with compressed air. That's it :-)
Seems like I read somewhere to be very careful if using compressed
air, or not to use it at all; the mesh screen is extremely fine mesh;
get a high power narrow nozzle too close and you may damage the screen/filter. I used to clean that filter; not sure if it is necessary
if you use lint free rags when checking the fluid level, keep the dipstck all the way in and locked down, and flush it now and then
and do it properly.
I think NAPA stocks an inline ATF fliter that you can put in the cooler lines; it has a magnet in it and filter medium; not sure however
about the flow of the filter and the required flow of the pump;
it does pump the fluid extremely fast; something like ?10 gallons
a minute as I recall??
When I had my tranny flushed I had the mechanic use 16 quarts of Mobil 1 Dexron III Synthetic ATF; they used a B&G tranny flush machine. Hard to find mechanics who have them; but I think they are
better than what most places use. Most lube shops use a machine
that has a filter, that they never replace; most don't even know
that the machine has a filter!
Before I flushed it, I added two bottles of LUBEGARD tranny flush;
hard to find; NAPA can order it however. Be sure to ask NAPA
to order you some fresh stock; they do not sell a lot of it,
so it may have been on the shelf for a few years.
It is supposed to be much more gentle on trannies than any of the other products; no harsh solvents, but I can tell you;
no question, my tranny shifted crisper than it has it 5 years
after I did that clean and flush; really.
Be carefull of dealerships; most only use around 6 quarts of tranny fluid when they do a flush; they also add a cleaner; but
by only flushing with 6 quarts, they leave most of the cleaner behind.
I learned that the hard way; had it flushed by a dealer, then checked my fluid; still a little bit of sediment; so, after 10,000 miles, had
it flushed again, at the dealer; still some sediment.
But this time, I checked it before I left the dealership, so,
I went back and asked the service writer how much fluid they use
for a flush; he didn't know, but went and asked; the answer;
"we use 6 quarts on all vehicles; they all are the same anyways"
NOT. got to ask the question.
Good luck
Great write-up, gray :)
I believe there is a way to flush the tranny yourself by disconnecting a hose... I think Rodney in OZ had made a post about this that I saw not so long ago... And yes it does take 3 gallons for full replacement of the fluid...
