Tranny cross member engineering
So I'm building a tranny cross member to take advantage of the AA tranny/t-case casting for a mount. I'm using 1x1.5x.125 rectangle tubing 31 inches long for the cross member. I want to plate the ends to create a bolt on piece so what thickness would be best?
I have some .125 plate that I can use or should I consider using 0.375 thickness to counteract the lateral movement? I can gusset the .125 plate to add strength but don't want to do a lot of work only to have it fail.
Is .125 tubing strong enough to handle the load? My thoughts are that the motor mounts carry the engine weight and the rear crossmember shares a small portion of this weight plus the weight of the tranny and t-case. Any idea what the weight distribution is between the motor mounts and rear tranny mount?
NP 435 behind a Ford 5.0 HO w/ stock 3 speed t-case.
