Tranny cover - easy question
Flagstaff, AZ
I have a '71 FJ40 that I am installing a 4 speed tranny in - looking on SOR's website there is a tranny cover for E-9/72 (no holes) and 9/72-1978 (with holes).
Are the tranny covers the same or are they year specific?
The 3 speed tranny tunnel is different from the 4 spd one. Easy to modify with an angle grinder. My rubber gasket covered everything and the mod was invisible.
When I installed a four speed in my 68 I used a tunnel cover from a 74-78. and just cut the back off (it's longer). The holes match up for four speed with floor shift for the transfer. If your keeping the vacuum shift then that would have one to many holes. The four speed tunnel cover is a little taller than the three speed. Besides cutting it I had to flatten the right side a little to match the floor. If the ones that SOR sells are made from fiberglass is might be harder to get the later style to work.
John
