Trailering your 40
Boulder, CO
I have searched but did not find. What are the best attachment points on your 40 when you are trying to secure it to the trailer? I have a gooseneck tandem axle trailer with electric brakes and an F250 tow vehicle. I currently use four very heavy tie down straps with two at the front bumper (CCOT) and the other two hooked into the frame above the rear axle on the 40. Are these good locations on the 40 to secure for trailering over long distances?
IMO, the frame is a poor choice for hookup....as the trailered rig moves around, the suspension will compress/release and it'll shock load those straps. Additionally, it can jar thru the trailer into the tow rig, and turn a poor road into a nightmare.
I likewise tie mine off at the axles and allow the 40 to move/suspend independantly from the trailer. LOTS of miles this way, no problems.
I tie down in a similar way that you do, except that I use (2) 3/8" chains w/ boomers instead of straps. On the front I have two shackles on the bumper and run the chains through these. On the rear I run the chain through the pintle hitch. Worked fine for trips to Moab, Arkansas, etc. If you use two on the front, cross them (i.e. driver's side attachment to passenger side of trailer).
Regardless of the method/type you use, it is important to continually check to make sure everything is tight.
I'm a firm believer in NEVER hooking to the frame, I have used chains with binders and big ratchet straps for mine and I wrap it over the differential and then under the axle tube. Try hooking to the frame on a tubular buggy and you'll see what I mean. Like Woody says, the shock is so bad it will bend the tubes.
That may be true, and this may be due to IFS or other issues, but have you ever seen a professional car hauler with straps around the axles? I hate having my 40 bounce around on its springs when I tie it down by the axles. That's why I tie it down by the frame, tightly, so it can't bounce (or very little).
X2.
I only trailer a race car now and not the 40 but still only use the axles.
my 40 ain't IFS...lol
Pro car haulers will tie down with the tires themselves, using clips/nets specially designed for such purposes.
The big rig haulers aren't hauling around a softly suspended truck either, with oversize and aired down tires, on a relatively cheap car trailer that likely flexes as it moves down the road.
Basically, tie the rig down and jump on the bumper/tub...if it moves AT ALL, that motion will be much worse on the highway.
I towed a few times by tying to the frame, and then switched to the axles on the recommendation of some friends...it was simply an amazing difference.
I guess I'm all screwed up, cuz I use a chain on the front, around the tow hooks, back the rig up to tighten the chain and compress the springs, then tie off to the rear axle with two ratchet straps. :hillbilly
I've always used heavy duty straps on the front(hooked up to my bumper shackles) and cinched down very tight. Then 3/8" chain and boomer around my rear axle. The most obvious thing tho, is definetly re-cinch the front straps after everything is all locked down. Wouldn't hurt to do it again after driving 5 or 10 minutes either. Never had a problem. Of course, it only takes 1 time.
Axles!. drove it on a flat bed for 1500 miles last summer. Not a problem at all, just some suspension roll on corners. Pay attention to the advisory speeds on corners.
I have had Cruisers and regular cars transported across country. In all cases, the professional hauler I used, secured the vehicles by the frame, and tightened the chains until the suspension was fully compressed. And I do mean fully. They broke two chains while tightening down the vehicle.
I don’t think I could compress my suspension to a point there would be no movement during hauling as my trailer is not designed to have to have numerous tie down points directly below the vehicle frame to allow a chance to compress the suspension. The shock load as mentioned earlier on those chains/straps can be severe.
Due to that, I have always been an axle wrapper. I use two chains or straps front and rear. Don’t use one strap per axle as the vehicle can slip/walk side to side.
Whatever method you use, check often as others have said. Also make sure you do not have a slow leak in one of your tires, if it goes down, you will get a slack chain/strap.
Jerry D.
When I haul my Red truck behind the Dodge on the single-place trailer, I have a chain around the front spings from side to side, and one in the rear, just the same, with a chain binder on each chain....have done it that way since '92. Trips all over the country, no issues...
When I haul this load, all three trucks are secured with four chains and four binders, to the frame, compressing the suspension....
HOLY COW!!!! THat's an awesome pic, like a dream come true!!
1 chain for the front one for the rear, both with binders and attached to the frame. I went this route after looking at semi trucks on the road hauling other trucks or cars. Also, don't want to damage the hard lines on the axle housing. Never had any issues with this method.
