Trailer Wiring Question
Southeast USA
So I am in the process of building a trailer dedicated for football tailgating. I'm at the point where I'm going to start electrifying the trailer with this basic plan:
Group 27 deep cycle battery to power:
  • Marine stereo
  • ARB fridge freezer
  • LED lighting
  • USB ports for charging electronic devices
I'm also going to install an on board battery charger so I can run the ARB fridge freezer 24/7 when it is parked at home to minimize having to load/unload condiments and drinks from the ARB. It will also allow me to top the battery off if necessary using a Honda EU2000i at the tailgates (we also use the generator to power a TV and satellite dish during extended tailgates).
My question is do I need to run a ground wire from the battery to the trailer frame and/or from a ground distribution block to the trailer frame to complete the circuit?
I have the trailer running lights grounded to frame. Will adding a ground from essentially a closed circuit cause any issues with the trailer lights and/or vehicle systems (towing with an LX470).
Thanks in advance.
Definitely ground to the trailer. One thing I would consider using is a Blue Sea, either 6 or 12 circuit box. I'm assuming your charger is 110v. I really like the NoCo stuff. There make an awesome weatherproof plug, and weatherproof chargers as well.
Thanks to you both. I have a Blue Sea 6 circuit panel waiting to be installed and had thought about picking up a negative buss bar to simplify routing a ground wire to the trailer frame. I've got one of the NoCo power inlets so I can plug an extension cord into the charger without having to open the door on the trailer. Based on the advice here, I'll do just that.
Thanks again.
  • Marine stereo
  • LED lighting
Thanks in advance.
An isolated 120 volt ground wire (green) should be run since the generator is not grounded but with its own internal wiring
