Trailer Wiring Problems
Austin, Texas
Having some troubles this weekend getting my pop-up camper ready for camping season. Every time I turn the running lights on, it blows the 10a fuse on the camper. After much chasing & tearing the camper apart to try & find the problem, it appears there is a short to ground on the Cruiser, and that the camper is just fine.
After tearing out the rear of the Cruiser chasing wires, I came across some stuff that is completely foreign to me. Can anyone tell me what the following black box is for, and why it's needed (if it actually is)? Any reason I can't pull all this rats nest out & start over? There is one wire from the box that runs across to the driver's side, and taps into the harness there.
I have continuity between the ground on the four-wire trailer plug, and the running light circuit, which must be what's blowing the fuse on the camper.
Any help is greatly appreciated. I'd like to get this thing on the road!
Box & wiring as found on the passenger side:
Wiring where it taps in to the drivers side harness:
ghetta fab LOL. Looks like the adapted trailer harness for your 80. Those type of "splices" I have had nothing with problems with. IMO the issue is the way the trailer harness is wired into your rig. Do a search here on 'mud. Plenty of conversation on trailer wiring harness and which ones to use vs problem childs.
(sorry I didnt' do mine, just my .02)
EDIT: In the last pic, where does the green/black wire go (the one that looks like its taped to chassis??
EDIT2: Sorry, but hopefully thats not a ground wire taped to metal?!?
I believe that green/black wire that has the splice connector on it is what ties the 'black box' into the driver's side turn signal. It runs under the carpet across to the passenger side well under the sub, where the box is.
I did some searching and found the Drawtite & Hoppy part numbers for the plug & play system. Not having much luck finding those parts online though - might have to swing by my local RV store on Monday & see what they can find.
Does anyone know if I can test the black box somehow to see if it really is the culprit? Hate to go spending money on parts if that's not really the cause. I'm an electrical nimwit though, and not really sure (aside from ripping everything out & starting over) how to find the short if its not in the box.
Do you also have extra turn lights from an ARB or Kaymar bumper? With those extra lights and a trailer, many of us have experienced the same blown fuse - too many lights once you add the trailer to the load. Couple of things - unplug the ARB or switch your trailer lights to LED. Later solved my problem.
I'll second the recommendation to go get a Hoppy - plug and play into your wiring harness - no splicing necessary!
I've got an ARB up front, but that's it.
It wasn't blowing fuses on the Cruiser though, it was blowing the 10a fuse on the trailer's running light circuit. All the other light systems work fine (turn & brake).
Definitely going to look into the Hoppy system.
