- Joined
- Feb 2, 2004
- Threads
- 115
- Messages
- 327
I tow a few trailer with my 80. I noticed when I turn either turnsignal on both right and left would turn on the trailers. It does this with both trailers so I suspected the wiring in the Landcruiser. It traced the 6 pin wiring to the passenger side panel near the fold down seat. I noticed four wires with a factory connector plugged into the factory landcruiser harness. The pigtail went to a black box labeled something like "Toyota trailer adapter" or something close. I disconned the pigtail and tested the output of the black box with, the right turn signal, left turn signal, brakes lights etc. I had the same experience, while the lighs and brake light both turnsignal wires would light up with a tester when either turn signal was one. I suspected the black box as the source of the issues so I tested the wires going into the box. These all worked as they should. The problem is five wires go into the box and the standard four wire trailer hook up comes out of the box. My question is do I need to get a toyota replacement box or are generic available.
Thanks,
Joe
Thanks,
Joe
