- Joined
- Nov 11, 2013
- Threads
- 1
- Messages
- 7
i have not done a ton of hauling/trailering and always got a little nervous when pulling something and so had some questions about a new project of mine. i had this little utility trailer and wanted to use it to haul a custom motorcycle i built. i upgraded to the 12" wheels shown and built a rail for my bike to go on. also added a longer tongue. the trailer is rated at 1000# and my hitch is rated at #2000. i am guessing the bike weighs between 700-800 and another couple hundred for the trailer...so getting pretty close to if not slightly exceeding the trailer rating. the tires are c rated/1880# (990 each). my questions are:
how concerned about the 1000# rating should i be?
even though the tires are well within the load rating, they just look "small" to me and should a beefier tire be used, or is the load rating what i should be concerned with? (again i am at only about have of what the tires are rated for)
i did take it out for a test run with the bike on it. drove around the neighborhood as well as got it up to speed on the highway. everything seemed fine other than i could "feel" the trailer back there and a sort of pulling sensation. i am just using a little chevy 2wd 6 cylinder crossover to pull it. i suppose thats somewhat normal being as i dont have a ton of power?
and lastly i have considered flipping the axle to lower it a bit to make loading a little easier. i know i would need to raise the fenders, but otherwise is this an okay thing to do? i have seen some posts where people dont recommend this, saying it puts too much stress on the u-bolts and relys on them to take the weight vs the axle itself.
i apologize for the lengthy post. any help would be greatly appreciated. thanks!
