Trailer lights connector
Panama
I'm new to this forum and would appreciate anyone who can point me to connector position where trailer lights harness and brake controller harness can be plugged in (plug and play). This is for a 2016 LAND CRUISER 200 plat edition Diesel engine European specs. This car has connectors everywhere but have not been able to locate the one that carries light signals and one for brake controller. I see 30 amp fuse assigned to towing so assume this car is set for plug and play lights. Not so sure about brake controller. My previous LC 2005 had four pin connector under cargo space next to spare tire and I was able to find matching harness for plug and play. Hope I can do same with this one. Thank you for any guidance you are able to provide.
Brake controller plug is in the dash to the left of the steering wheel.
Real time help: trailer brake controller location?
As to the wiring harness under the vehicle - you may need to look at the GSIC since all US-spec LCs and LXs get it installed at the port by default and so the majority of the members here probably haven't had to trace this.
As an aside, the defualt location of the wiring harness sucks, so if you need to procure one it's probably for the best as you'll be able to route it somewhere that isn't so far under the vehicle and to the side that most trailer plugs won't reach with the proper slack
If it's similar to our LX570 it's underneath the dash panels to the left of the steering wheel (for left hand drive). You have to remove the panels starting from the bottom and work your way up until you can reach the connector for the brake controller. Then you have to route the wiring to a location where you want to mount the brake controller.
