Trailer flat four wire routing (1 Viewer)
AZ
Hey dudes. I was working on my trailer wire that goes from inside the passenger rear fender and exits to the outside. When I pulled it through the fender into the cargo area I did not pay attention to where it enters/exits the vehicle. When I pulled it out a rubber grommet also came out. For the life of me I can't find the hole (smart ass comment should be coming soon) does anyone have a pic of where I need to run the wire out through or can you at least describe where the exit hole is? I would like to put it back through the right spot and reuse the grommet. Thanks.
Southwest Georgia
most likely the very rearward inner side of the passenger cargo space where there is a small hole near the bottom of the sheet metal. This is the same hole I ran my trailer wiring through. If you go underneath the vehicle and look up above tailpipe on the cargo area inner vertical piece of sheet metal you should see a hole. Almost at the bumper. It can be hard to feel as it is fairly far back on inside and bottom of the panel, but you should be able to see from underneath if it is the same hole I am describing. Hopefully this helps, hard to describe.
AZ
Thanks Tredwards. I ended up running it through the hole for what I think is the sunroof drain.
