Trail Teq 90 Series Plug-and-Play Keyless Entry - New Product Release
Trail Teq
Supporting Vendor
Australia
Website
www.trailteq.com.au
Hey everyone! Just letting all 90 Series owners know that I have now finalised the Plug-and-Play Keyless Remote Entry kits to suit 90 Series Prado's that came with factory central locking.
There are currently three versions of this kit, two are available for sale at the moment with the third version nearly finished pending prototype testing.
1. Australian Market Models (all production dates) - Available now on the Trail Teq Store
2. Global Market Models (E.g. JDM / Europe / UK / USA) Up to production dates 06/1999 - Available now on the Trail Teq Store
3. Global Market Models (E.g. JDM / Europe / UK / USA) Production dates 06/1999 onwards - Available approx. April 2026
For those familiar with our flagship 80 Series Kit, this 90 Series version works in exactly the same way.
- Plug and Play into existing body loom connectors in 5-10 minutes, using OEM connectors and custom wiring harnesses.
- No cutting wires, splicing, tampering with anything. 100% plug and play with the provided wiring harness.
- No coding required.
- Indicator Flashing on lock/unlock.
- Standard two-button remotes, or optional Flip Keys (read the Flip key tab on the product description for more info on those).
- Kits to suit all markets of 90 Series, whether it is an Australian delivered model, or a Global Market Model (E.g. Japan, USA, UK, Europe, etc).
For this weekend only, I'm also doing 10% off on these 90 Series kits. Just use the code PRADO90 at checkout.
Full details are in the product descriptions, but feel free to PM me / ask any questions you might have.
Pricing is a bit cheaper than the 80 Series kits too, as these 90 Series kits require less wiring and labour on my part!
Price starts at $175 AUD, up to $275 AUD + postage, depending on options.
The Australian Market kits are a bit cheaper as they require less wiring (thanks to Toyota Australia putting some of the wiring into the body wiring already).
90 Series Prado Plug-and-Play Keyless Remote Entry - https://trailteq.com.au/products/90-series-landcruiser-plug-and-play-keyless-remote-entry
And a big thank you to the few people who helped test the prototype kits. I'm not sure if they are on ih8mud or not, but thank you!
Hey Ian, no this system is completely independent of the Toyota system.
The modules I use have a capacity for two coded remotes at a time. New / replacement 433mhz remotes can be programmed directly to the unit using a built in learning button. I provide instructions on how to do this for customers who need to do it for whatever reason.
You guys are awesome! Just ordered my kit! Cant wait. Is install pretty easy?
Thank you! I think I've made it as easy as it possibly can be.
Nothing major needs to come out, just the driver kick panel plastic trim (a few screws) and the plastic fuse box cover for the main unit.
For the optional indicator flashing loom, you will have to unplug your hazard light switch to plug in a patch loom there, so the trim piece around that (or you can pry the switch our without doing that, but I suggest not too incase you damage the trim piece / tabs on the switch housing)
@Trail Teq Do you know if this system will work with the ones that have dealer(JDM) installed keyless entry??
Hey!
Yes it will work, you can remove it or leave the old JDM system in place if you have that already without it having any impact on the Trail Teq system.
