RockCrawler.com Trail-Safe™ Samurai Inner Axle Seals
Tired of dealing with oil leaks from your front inner axle seal? Trail-Gear has remedied that*issue by offering our new Trail-Safe™ Samurai Inner Axle Seal. The Trail Safe™ inner seal lip*is totally supported by a garter spring applying constant force over the full 360º circumference.*This prevents any deflection gaps and stops oil from bypassing the […]
The post Trail-Safe™ Samurai Inner Axle Seals appeared first on RockCrawler 4x4 and Offroad Magazine.
Related posts:
  1. Trail Safe Inner Axle Seal
  2. Rock Assault™ Trail Nine Axle Housings
  3. Rock Assault™ 9″ Seal Housing Kit
31c1d89980ea4a98f69e1b3224de7977
Tired of dealing with oil leaks from your front inner axle seal? Trail-Gear has remedied that*issue by offering our new Trail-Safe™ Samurai Inner Axle Seal. The Trail Safe™ inner seal lip*is totally supported by a garter spring applying constant force over the full 360º circumference.*This prevents any deflection gaps and stops oil from bypassing the seal lip. The outer seal lip*acts as a secondary seal and keeps debris and other contaminants away from the inner seal lip.
The O.D. of the Trail Safe™ Seal is 100% rubber coated so that it forms a complete static*surface seal resulting in zero leaks, and the outer flange prevents the seal from being pushed too*far into the axle housing. This is by far the most effective inner axle seal on the market, and will*help you keep your favorite trails free of oil.
Application Data:
• 1986-1995 Suzuki Samurai (All Engines)
Trail-Safe™ Samurai Inner Axle Seal, 300748-3-KIT (PAIR), $15.75
Related posts:
Link
