- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
Tired of dealing with oil leaks from your front inner axle seal? Trail-Gear has remedied that issue by offering our new Trail-Safe™ Nissan Patrol Inner Axle Seal. The Trail Safe™ inner seal lip is totally supported by a garter spring applying constant force over the full 360° circumference. This prevents any deflection gaps and stops oil from bypassing the seal lip. The outer seal lip acts as a secondary seal and keeps debris and other contaminants away from the inner seal lip.
The O.D. of the Trail Safe™ Seal is 100% rubber coated so that it forms a complete static surface seal resulting in zero leaks, and the outer flange prevents the seal from being pushed too far into the axle housing. This is by far the most effective inner axle seal on the market, and will help you keep your favorite trails free of oil.
Note: Direct replacement for your OEM Nissan Inner Axle Seal (OEM number 40533-01J00).
Application Data:
1987-1997 Nissan Patrol GR (Y60), All Engines
1987-1997 Nissan Patrol GQ, All Engines
1987-1997 Nissan Patrol Safari, All Engines
1987-1997 Nissan Safari, All Engines
1988-1994 Ford Maverick, All Engines
Nissan Patrol GR (Y61) 1997-2013 (All Engines)
Nissan Patrol GU 1997-2013 (All Engines)
Nissan Patrol Y61 1997-2013 (All Engines)
Nissan Safari 1997-2004 (All Engines)
Nissan Patrol Super Safari 1997-2013 (All Engines)
Trail-Safe™ Nissan Patrol Inner Axle Seals (Pair), 303752-KIT, $16.54
The post Trail-Safe™ Nissan Patrol Inner Axle Seals appeared first on RockCrawler 4x4 and Offroad Magazine.
Related posts:
Continue reading...
Application Data:
Related posts:
- Trail-Safe™ Samurai Inner Axle Seals
- Trail Safe Inner Axle Seal
- Trail-Gear is now offering a Nissan Patrol ARB and Detroit Locker
Continue reading...
