Trail Removal: Speedo Sensor Wire
Pacific NW
I'm not really sure how this one happened, but the three wire going to the transfer case speedo sensor got pulled out of the plug.
I don't have a wire diagram yet. Can somebody please let me know the proper pin-out?
Also, any thoughts on me being able to re-pin this connector?
Thanks,
When you get back home, clean off the connector and look for a 3-digit code. This will be the code for the plug. When you order the plug they can also get you repair pigtails.
Sweet. Dan is going to get sick of me real quick.
I didn't rip mine out, but clocked mine pretty good last time out as well. Started dripping fluid to. Received a new o-ring to install.
Anyone have a way to prevent this? I've always thought that thing looked vulnerable.
/me points to his sig
It's possible I'll hit mine or rip mine out. But it'd be very very difficult to. ;)
I didn't rip mine out, but clocked mine pretty good last time out as well. Started dripping fluid to. Got received a new o-ring to install.
Wouldn't you rather hit a skid plate? :hhmm:
This just happened to me a couple of weeks ago. It shorted out the gauge fuse. Which also powers the windows. Which were down. Then it started to rain. Then came the hail. And the lightning. At this point the :princess: asked pointedly, "Where am I going and why am I in this handbasket?"
But I digress. You need p/n 8225 160050 Wire, Speed Sensor. It's about $43 before the Cruiser Dan Discount. In the mean time, you could beg 3 pigtails from your friendly dealer, and wire them up to plug Ea1. Pin 1 is yellow, pin 2 is red, pin 3 is brown.
I broke the whole damn sensor off the transfer case, and cut two of the three wires in the process. Thanks to Slee for selling me a used one at a good price.
So in one of my feets of patients, I actually was able to disassembles the connector and remove the pins. I then re-assembled the connector with 6" of wire. (normal plane jane wire; problem?)
Per your info above, I souldered my 6" of wire to the truck wires. I again resisted the temptation to do it half ass with crimp connectors. Sauder, heat shrink, & split loom.
Wire tire the wire out of the way, install my new Slee skid plate, now time for a test drive.
Still no speedo. Any ideas? I would assume 1 wire is power, 1 is ground, and the other is the signal. Which is which?
Can somebody please help me with this!
I wired up the way recommended and it didn't work.
Yellow = 12v
Red = 7v
Brown = ground
Connector pn is:
11143 08
UWDave,
I just bought a used VSS and got the whole connector plug with it. I only needed the sensor so if you want the connector; I'm over in Bellevue.
Cheers,
Salue
Salue
THanks for the offer.
Any chance you could just look at the connector and tell me what color wires go into which pin. (they should be numbered on the connector)
Thanks.
And he said let there be speedometer. And there was. And it was good.
Salue's info above worked for me.
