- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
Protect your U-Joint from unnecessary damage. Our Rock Assault 9™ Pinion Guards are*CNC Laser Cut and formed from 3/8” thick A36 Steel. This upgrade is available for standard*and flipped housing configurations. These are designed to fit factory Ford 9” housings, and*aftermarket replacements. Part is shipped raw and lightly oiled for rust prevention. NOTE: 3/8″ longer […]
The post Trail-Gear Rock Assault 9™ Pinion Guard appeared first on RockCrawler 4x4 and Offroad Magazine.
Related posts:
NOTE: 3/8″ longer fastening hardware is required. Length will be dependent on model of*pinion support
Available Options:
• Rock Assault 9™ Pinion Guard, Standard, 301080-KIT, $47.25
• Rock Assault 9™ Pinion Guard, Flipped Housing, 301081-KIT, $47.25
Related posts:
Link
Related posts:
- TRAIL-GEAR RELEASES ROCK ASSAULT™ 9 AXLE HOUSINGS WITH 3.5-INCH TUBING
- Rock Assault™ Trail Nine Axle Housings
- Rock Assault™ 9″ Seal Housing Kit
Protect your U-Joint from unnecessary damage. Our Rock Assault 9™ Pinion Guards are*CNC Laser Cut and formed from 3/8” thick A36 Steel. This upgrade is available for standard*and flipped housing configurations. These are designed to fit factory Ford 9” housings, and*aftermarket replacements. Part is shipped raw and lightly oiled for rust prevention.NOTE: 3/8″ longer fastening hardware is required. Length will be dependent on model of*pinion support
Available Options:
Related posts:
Link
