RockCrawler.com Trail-gear releases roll cage and suspension components for jeeps
Fresno, CA-Trail-Gear, Inc. plans to shake things up with the launch of three new Jeep products.*Trail-Gear will be debuting a new roll cage for Jeep Wranglers made from years 1987-1995*(YJs), front lower control arm brackets and cam bolts for Wranglers, Cherokees and Wagoneers*with the following Body Style Designations: TJ; TJ-L or LJ; XJ; ZJ; and [...]TRAIL-GEAR RELEASES ROLL CAGE AND SUSPENSION COMPONENTS FOR JEEPS is a post from: RockCrawler 4x4 and Offroad Magazine
Fresno, CA-Trail-Gear, Inc. plans to shake things up with the launch of three new Jeep products.*Trail-Gear will be debuting a new roll cage for Jeep Wranglers made from years 1987-1995*(YJs), front lower control arm brackets and cam bolts for Wranglers, Cherokees and Wagoneers*with the following Body Style Designations: TJ; TJ-L or LJ; XJ; ZJ; and WJ, today (Friday, August*3rd). “We have a wide selection of off-roading products that every off-road enthusiast should*have,” said Matt Messer, Trail-Gear CEO. In response to customer requests, Trail-Gear will be*expanding into the Jeep market. “We saw a need for high-quality yet affordable Jeep parts in*the market and want to be the one to fill it,” Messer explains.
Trail-Gear will be releasing their new Rock Defense™ YJ Roll Cage. It is a do-it-yourself, weld-*together cage that adds-on to the existing roll bar. Made from heavy-duty 1.75”x .120” wall*DOM material, it replaces the weak stock A to B pillar braces and offers more protection in the*event of a roll during on and off pavement adventures. The Rock Defense™ YJ Roll Cage has*been engineered for Wranglers made from 1987-1995. It fits YJs with either hard or soft tops*and requires welding for assembly.
Trail-Gear will also be releasing their Jeep Front Lower Control Arm Brackets. These brackets*are designed to upgrade the stock front lower control arm brackets on TJ and TJ-L or LJ*Wranglers and XJ, ZJ and WJ Cherokees or Wagoneers with Dana 30 or 44 front axles. The Trail-*Gear brackets are made from heavy-duty ¼” thick steel and will strengthen the suspension*mounting points, allowing drivers to take on bigger obstacles on the trail. Brackets are sold in*pairs.
Additionally, Trail-Gear will be releasing a set of heavy duty Jeep Cam Bolts so that customers*may upgrade their stock bolts when upgrading their brackets, instead of re-using the stock*bolts. The Trail-Gear HD Jeep Cam Bolts are specially engineered to fit Jeep Lower Control Arm*Brackets on TJ and TJ-L or LJ Wranglers and XJ, ZJ and WJ Cherokees or Wagoneers with Dana*30 or 44 front axles. They are rated Class 10.9 and zinc-plated for corrosion resistance. Each kit*includes hardware for both Lower Control Arm Mounts which includes two bolts, two lock nuts*and four Cam washers.
Interested parties may purchase the Trail-Gear Rock Defense™ YJ Roll Cage, the Jeep Front*Lower Control Arm Bracket and the Jeep HD Cam Bolts from any authorized Trail-Gear dealer*or via the Trail-Gear website (www.trail-gear.com). The Trail-Gear Rock Defense™ YJ Roll Cage*retails for $239.99, the Jeep Front Lower Control Arm Brackets retail for $69.99 and the Jeep*HD Cam Bolts retail for $34.99 on the Trail-Gear website.
All design and development for the Trail-Gear Rock Defense™ YJ Roll Cage, the Jeep Front*Lower Control Arm Brackets and the Jeep HD Cam Bolts were done at the Trail-Gear, Inc. world*headquarters in Fresno, California. Manufacturing for the Rock Defense™ YJ Roll Cage and*Jeep Front Lower Control Arm Brackets is also done at the Trail-Gear headquarters in Fresno,*California.
Trail-Gear, Inc. is an industry leader in quality off-road product design and manufacturing.
Link
