- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
The Trail-Gear FJ80 knuckle rebuild kit contains all of the replacement parts you need to service your steering knuckles including gaskets, felts, seals, spindle nut & washers, and shims. New spindle bushings, trunnion bearings, and steel outer felt covers are also included. The stamped steel outer felt covers are not found in other most other kits. If you’re using your FJ80 in the rocks you will want to replace these covers when you service the knuckles. The FJ80 Knuckle kit has all the parts you need to service both left and right knuckles. Available with or without wheel bearings.
Available Options:
FJ80 Knuckle Rebuild Kit, 303441-1-KIT, $72.45
FJ80 Knuckle Rebuild Kit w/Wheel Bearings, 303749-1-KIT, $124.95
The post Trail-Gear is now offering FJ80 Knuckle Rebuild Kits appeared first on RockCrawler 4x4 and Offroad Magazine.
Related posts:
Continue reading...
Available Options:
Related posts:
- Trail-Gear Samurai Super Metal Knuckle Bolt Kit
- TRAIL-GEAR EXPANDS OFFERINGS FOR FJ80s AND TRAIL TAGS LINE
- Trail-Gear is now offering Jeep YJ Rock Sliders
Continue reading...
