RockCrawler.com Trail-gear adds power steering pump with tacoma serpentine pulley kit to rock assault
Fresno, CA-In response to customer requests, Trail-Gear has expanded its Rock Assault™ line with the*addition of a Power Steering Pump with Tacoma Serpentine Pulley kit, released today (Friday, June 15,*2012). This new steering kit combines Trail-Gear’s 1,450 PSI or 1,650 PSI power steering pumps with a Tacoma*Serpentine Pulley. The TC style power steering pumps feature [...]TRAIL-GEAR ADDS POWER STEERING PUMP WITH TACOMA SERPENTINE PULLEY KIT TO ROCK ASSAULT™ LINE is a post from: RockCrawler 4x4 and Offroad Magazine
This new steering kit combines Trail-Gear’s 1,450 PSI or 1,650 PSI power steering pumps with a Tacoma*Serpentine Pulley. The TC style power steering pumps feature all steel housings to handle extreme*heat and put out 4 GPM or 4.5 GPM of flow and 1,450 PSI or 1,650 PSI of pressure, respectively. Each*pump is bench tested to ensure quality. The 1,450 PSI pump is designed for use in a hydraulic ram assist*application and the 1,650 PSI pump will run all full hydraulic applications popularly used in rock crawling*today. The 1,650 PSI pump has a #6 JIC male fitting on the pressure port and a #10 JIC fitting on the*suction side.
The pulley is precision CNC machined from 6061 T6 Aluminum and anodized red for corrosion-*resistance. The center hole bore diameter is .660″ and the total outside diameter of the pulley is 4 3/4″. The serpentine pulley fits 2.7L and 3.4L Tacoma applications in addition to many other common*serpentine belt applications that use a 4 rib belt.
The design and development for the Trail-Gear Rock Assault™ Power Steering Pump with Tacoma*Serpentine Pulley kit were done at Trail-Gear, Inc. in Fresno, California. Trail-Gear exhaustively tests all*of their products at some of the world’s hardest courses, such as “The Hammers” in Johnson Valley,*California and the Rubicon Trail in Lake Tahoe, California. Interested parties may purchase the Trail-Gear
Rock Assault™ Power Steering Pump with Tacoma Serpentine Pulley kit from any authorized Trail-Gear*dealer or via the Trail-Gear website: www.trail-gear.com. The 1450 PSI version retails for $179 and the*1650 PSI version retails for $229 on the Trail-Gear website.
Trail-Gear, Inc. is an industry leader in quality off-road product design and manufacturing.
Link
